boost issues? help!
chunk82
boost issues? help!
Post by chunk82 »
I recently installed s300 with the hondaga b oost solenoid on it and properly hooked up everything correct :) but I'm having issues.....when I hit 6k rpm my car just totally shuts off....n won't allow me to rev past that..... I checked my booost cut and it is set to 9.9 cause I'm using a stock map sensor...boost gauge also shows 10 psi when I hit 6k rpm n e suggestions on tuning n fixing this? I thought it might be a spark plug issue n I'm running the ngk r spark plugs? N e info well help thanks!
Re: boost issues? help!
From your description you are hitting a boost cut.
chunk82
Post by chunk82 »
I was thinking that too....but how would I tune it so my boost reaches 10psi @ redline then 6k rpm....... and thank u spunkster...I notice ur the only one responding to a lot of these post.....I really appreciate it since I'm new to hondata :)
Adjust the settings in boost control so that you make less boost so you don't hit the boost cut. Or you need to raise the boost cut.
chunk82
Post by chunk82 »
I tuned down the boost....and raised the boost cut to 12psi it ran fine for the first couple of runs then it went back n did the same thing....could it be a fuel problem cause I'm runin stock injectors? First gear rips through fine.......but second just seems to shut off around 6k rpm?
