P73 and S300
contectr
P73 and S300
Post by contectr »
Hi Hondata,
i have a P73 ecu on my integra Type R DC2 EUDM
The number on the ecu case is this:
37820-P73-G01
111-106275
It's possible install the S300 on this ecu?
Honda Ep3 stock k20a2 jrsc
Re: P73 and S300
No. To use a Hondata system, you will need to use a compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html. You can then use the Hondata s100 or s300 depending on what options you want (http://www.hondata.com/sproducts.html).
contectr
Re: P73 and S300
Post by contectr »
Ok Spunkster..
I Think the wire harness OBD I and OBD II ecu are different
I need a conversion wire harness for use the OBD I?
Re: P73 and S300
Correct.
contectr
Re: P73 and S300
Post by contectr »
It's possible buy this cable from Hondata or don't sell them?!?
Re: P73 and S300
Hondata doesn't sell directly. You should be able to get everything you need through one of the Hondata dealers listed at: http://www.hondata.com/dealers.html
contectr
Re: P73 and S300
Post by contectr »
Spunkster, ok this look about normal..
It's available this:
http://www.hondata.com/obd2promotion.html
I think it's the best solution, i can order them from italian Dealer Alientech..
Re: P73 and S300
The bundle is no longer avaialble.
