comuter wont connect to hondata
shipwreck89
Post by shipwreck89 »
running windows 7 laptop and hondata s200. just finished updating my device driver to run usb.
the problem is the data logger connects for only a second and then tells me there is a connection error.
ive tried connecting through all 8 com ports all with the same issue.
some help would be appreciated
Re: comuter wont connect to hondata
What is the serial number of the s200?
What software are you trying to use to datalog?
What software was it tuned with?
shipwreck89
not sure what software it was tuned with. i bought the ecu and s200 online as a unit.
i downloaded rom editor4 and hondalogger
serial number is s200 2456
also the red light on the box is flashing every 2 seconds
hope i didnt buy a bunk unit.. thanks for the reply
shipwreck89
i just read up on s200 users guide:
slow flashing red light:
The problem lies with the Hondata interface box not being able to communicate with the ECU. Possible causes for this problem:
• Incorrect ROM used for the ECU.
• ROM inserted the wrong way around.
if this is the case how can i resolve the issue?
my best guess is to open the ecu and check the ROM?
some techie help would be awsome!
This system does not have datalogging.
If you want this tuned you will have to take it to a Hondata dealer that can tune an s200. You will not be able to make any changes yourself with this system.
I highly recommend just upgrading to the s300 instead as it will be cheaper, has more options and is easier to tune. Details can be found at http://www.hondata.com/s300upgradeform.html
