just done my k swap speedometer goin crazy???
k24a2egcoupe
Post by k24a2egcoupe »
ok i have a k24a2 stock swap with tsx 6speed trans with prb k pro ecu ser#2068503036 an i have k manage 3.1.6 so when im rolling at 0-10mph it says im doing 60-100+ mph lol then it will just go back to 0mph an stay there untill i start off again or cruise at a low speed? an ive went under misc an set it to counter shaft driven speen sensor (tsx) an dosent change a thing. how do i fix this?
Re: just done my k swap speedometer goin crazy???
You really need to use an 02-04 RSX/02-05 SI transmission to get this to work properly. The transmission you are using is high frequency and cannot be converted to low frequency.
Details can be found at http://www.hondata.com/techk20transmissions.html
k24a2egcoupe
is a s2000 gauge cluster high or low frequency? could i just use it?
an will vtec hit with the speedo messing up?
No swapping clusters will not work and VTEC will not operate without a proper speed signal.
Screech
Post by Screech »
Just a question on this topic. Is that ECU able to support receiving the high frequency VSS and then outputting low frequency to the dash? If not which ECUs support this? I understand the harness would have to be changed a little so the HF-VSS from tranny goes only to the ECU and so the dash receives the LF-VSS from the ECU.
