help opening map onto Smanager
mathewtsab
Post by mathewtsab »
i have a Map that my brother used on his gsr build. made 206whp at paris engine dynamic in stockton california. setup was......
gsr block and internals with CTR pistons
Gsr head ported 3 angle valve job. n polisded
Skunk2 stage 3 tuner cams
skunk2 ported manifold.
Hytech tri y headers
E cut out
my problem is, i cant get this map to open on the Smanager. the map was made on crome. can anyone turn this into a regular hondata s300 file? if so can you fix it and reload it so i can use it. also, it was running 370cc injectors at the time. can you adjust it to run stock 240 injectors? your help will be greatly appreciated. thanks
Re: help opening map onto Smanager
You cannot convert crome files to work in Smanager. You will have to go to the New Calibration button and choose a calibration close to what you have and then begine tuning from there. You can also try searching the Vault for other people's calibrations that may be close to your setup.
http://www.hondata.com/help/smanager/se ... tsub=vault
