P72-003 CEL
ej1h22aturbo
P72-003 CEL
Post by ej1h22aturbo »
Hi,
i am having CEL issue and smanager showing code 13 Atmospheric pressure sensor and 16 Fuel injectors, have traced all wiring and checks out ok, i am running Injectors Dynamics 1000cc High Impedance, the only thing i can think of is because alternator is not connected batt voltage around 10.5volts would that cause to fault? ecu is JDM P72-003 with hondata s300 v2.
Re: P72-003 CEL
You will have to disable those error under Misc in Parameters since a JDM ECU does not have the circuitry for them. Why is the alternator not connected?
