FIC injector dead time?
dneilmotorsports
Post by dneilmotorsports »
I'd change the fic injector 1250cc yesterday, and i also change the dead time in my smanager. The problem is i can"t get 14+/- afr at idle like before..When i set the afr 14 then i switch on the acc, the afr go very lean and engine shut down..
Should i modified the dead time in smanager to make it run smooth like before? or maybe the fic injector spray pattern diffrent compare to the sard injector..plss help!!
Re: FIC injector dead time?
Dead times must be set properly before you start tuning.
