Creating boost table but it reverts back to default. HELP
PR8urvtec
Post by PR8urvtec »
Every time I create a boost table to retard .75*/psi and add 120% fuel and click ok the settings never apply. I click the boost table again and it's set to not change anything on both settings. I even tried to change the % per PSI and when I click ok it reverts back to default and doesn't change anything. What am I doing wrong?
Re: Creating boost table but it reverts back to default. HEL
That is not a setting window it is an adjustment window and it adjust the tables every time you use it. If you open it again it will let you make the same change over and over again, but it changes the tables every time you do it.
PR8urvtec
Post by PR8urvtec »
Thank you for clearing that up.
