S300v2 and analog input
contectr
Post by contectr »
Hondata, i have a S300v2 on my Integra B18 engine.
I have buy a Plx M300 Te wideband controller and now i'm ready to wire them on the ecu for start the tune..
I want to wire the 0-5v output on the pin analog input S300v2 board..
With this configuration i can see the lambda value and the fuel change % in the table?!
Honda Ep3 stock k20a2 jrsc
Re: S300v2 and analog input
No, if you want to be able to is use it that way you will have to wire it into one of the ECU inputs. The Analog inputs on the s300 are for datalogging only and will not be able to be used for calculating Lambda changes, running in closed loop or lean protection.
contectr
Post by contectr »
Spunkster, analog input like as B6?
Any of the inputs listed under Closed Loop in Parameters. Do not use D14 though as it can only read about halve of the voltage range.
contectr
Post by contectr »
Spunkster i have try the D10 pin ELD voltage and they work ;-) but is there any resistor to remove for clear the channel?!
aria
Post by aria »
Spunkster wrote:Any of the inputs listed under Closed Loop in Parameters. Do not use D14 though as it can only read about halve of the voltage range.
I have 2 O2 sensors in my car, 1 attached to D14 (NB) and 1 to the D10 (WB) , if i want to use WB for close loop daily , should i move it to D14? Or i can keep it at D10 and select option in Smanager?
Use D10 as it will be able to properly read the full range of voltage for closed loop operation.
aria
Post by aria »
Spunkster wrote:Use D10 as it will be able to properly read the full range of voltage for closed loop operation.
Appreciate your help...
