Display
Boyle.r
Display
Post by Boyle.r »
Is there a way to change MAP in display to show Kpa or Mbar rather than psi?
Re: Display
Yes change your units in settings, and in the sensor list.
Boyle.r
Re: Display
Post by Boyle.r »
I have done that. It still shows Map(psi) in display?
Re: Display
are the readings still in psi, or is it just labeled as psi. If it is just labeled PSI, then you can change the label by editing the display.
Boyle.r
Re: Display
Post by Boyle.r »
Spunkster wrote:are the readings still in psi, or is it just labeled as psi. If it is just labeled PSI, then you can change the label by editing the display.
I haven't done any datalogging yet. I'll try it later and see. Thanks for the help.
