Integra Type R S300
Jdmspice
Integra Type R S300
Post by Jdmspice »
If i upgrade my ecu to a Hondata S300, and there happen to be a check engine light come, will i still able to scan it through the OBD2 Diagnostic port??
Re: Integra Type R S300
No, the OBD2 diagnostic port is not longer functional when converting to OBD1, but you can read the codes using a laptop and the s300.
Jdmspice
Post by Jdmspice »
Thanks, can you scan through the s300 with a obd1 scanner?
I don't know of an OBD1 scanner. The s300 connects to the laptop via USB and you can datalog and read the errors.
Jdmspice
Post by Jdmspice »
Oh ok thanks, actually there are OBD1 scanners, Innova makes that can do both obd 1&2, just putting it out there, but thanks for the info though.
