KManager V3.2.4 (beta)
This release has improved rev / launch / burnout limiter operation.
V3.2.0 (18 Oct 2012) changes:
  • Improved speed of launch, burnout, shift and overall rev limiters.
  • Fixed datalogging of traction control over slip and retard.
  • Fixed traction control input descriptions.
V3.2.1 (18 Dec 2012) changes:
  • Fixed datalogs not downloading when the datalog memory is full.
V3.2.2 (20 Dec 2012) changes:
  • Fixed PRA calibration load.
V3.2.3 (14 Feb 2013) changes:
  • Reduced after start VTEC & VTC delay from 10 seconds to 1 second.
V3.2.4 (20 Feb 2013)
  • Added the option to use analog inputs for lambda datalogging.
Nazul
Re: KManager V3.2.0 (beta)
Post by Nazul »
Dear Hondata,
Whats the procedure to update the ecu of hondata.
Download the mapping in the new version of 3.2.0?
Then save the mapping again and reupload it?
Are these new fixes applied then automatically or how to I need to understand this?
You should already have the calibration saved on your laptop. Then just upload it to the ECU using the new version of software.
Nazul
Post by Nazul »
Ok thanks for the info
05typeR
Re: KManager V3.2.1 (beta)
Post by 05typeR »
Hi guys,
I just installed this software V3.2.1 on my PC and now im getting error message when trying to load a calibration file, I also update the laptop and now getting the same problem.
Update: i reinstalled V3.1.6 and everything works again.
What is the error message?
Arno
Post by Arno »
Same problem here with 3.2.1 on a Windows 7 netbook.
Easy to reproduce.
1> Start Kmanager 3.2.1 (no need to connect to ECU)
2> Button 'New Calibration'
3> Select 'Civic Type R (European) - PRA'
4> Select any of these, eg. k20a2-civictyper-factory.kal
5> Press 'OK'
Error window pops up: 'Could not load C:\Program Files\KManager\Calibrations\k20a2-civictyper-factory.kal'
Same error when opening a pre-existing KAL file.
It WILL, however, select and open a new PRB, PND and PNF calibration.
Perhaps some parsing issue with PRA (or non-PRB) KAL files?
Oh.. And KManager crashes after you try to open a PRA (and it fails) and then you select the 'Tables' button.
Probably because the data wasn't read properly and it's trying to display/process garbage data.
Bye, Arno.
05typeR
Post by 05typeR »
Thanks arno, that's exactly what's happening.
I'm using a PRA ecu
05typeR
Re: KManager V3.2.2 (beta)
Post by 05typeR »
Guys,
I tried the beta 3.2.2 and now im able to load my PRA files but when its connected to the vehicle it give me an error, i think it was something to the tune of kmanager had to close, i have to reinstall 3.1.6 again to regain any communication with my ECU.
Nazul
Post by Nazul »
Version 3.2.0 is working fine for me, i suggest not upgrading it meanwhile for PRA ecus.
05typeR
Post by 05typeR »
can Hondata have a section in the downloads where you can select past version of the software?
my last version was 3.2.0 but i can only download 3.1.6
05typeR
Post by 05typeR »
are you guys looking into this?
The above question.
We try to fix problems rather than create them. Why do you need to use an earlier version of the software?
fugazzyek
Post by fugazzyek »
the new version would fix my problem with the tps?
when i'll try to calibrate the "READ" wont light on
You need to have your calibration loaded and datalog to be able to calibrate it. Then when you are done you must upload the calibration to the ECU.
