PWM question
crazcj
PWM question
Post by crazcj »
i'm having issues with PWM boost control and was wondering if the PWM value should be displaying anything in "senors" tab in s300. i have 0% at idle
Re: PWM question
It will only activate when the parameters are met.
crazcj
Re: PWM question
Post by crazcj »
so 0% is normal?
Re: PWM question
If the parameters have not been met to turn it on, it will be 0
crazcj
Re: PWM question
Post by crazcj »
What could I set the parameter to @ idle to have it engage?
Re: PWM question
a map pressure with more vacuum than you are reading from the map sensor.
crazcj
Re: PWM question
Post by crazcj »
ok so i got it to work, but the duty cycle percentage is really high. for example 60% is 10 psi, and i cant hit 45-50 psi how do i alter that? riight now i have the variable frequency box unchecked.
Re: PWM question
Try different frequencies, it should help you find a better resolution for the duty cycle.
crazcj
Re: PWM question
Post by crazcj »
ok so what is the default frequancy?
would you recommend higher or lower?
shanebadoo
Re: PWM question
Post by shanebadoo »
31 hz is right around where the hondata mac solenoids function well at. Gm solenoids like the higher frequencies. If you have the hondata /mac solenoid, tyr 31hz and report back here.
