VTEC problem that no longer engages (no error code)
Titi
Post by Titi »
hello, I'm new to the forum, my name is Thierry and I live in France. I have a problem on my D16Z6 civic turbo, it works fine but one day I wanted to make a change in smanager and I realized that my VTEC not does engaged. online I do not go into high tables and now that no longer engages VTEC I can go.
excuse my bad englais.thank you for your response.
Titi
Re: VTEC problem that no longer engages (no error code)
Post by Titi »
nobody to help me? help me please. I'm lost
Titi
Post by Titi »
hello, it is a civic EJ2 95, P72 ECU, engine D16Z6 forged,boost control HPI,S300 serial number: 11656
for recording data I can not because I took out my engine
If the engine is out, there really isn't anything to troubleshoot. All you can do is try your ECU on a known working vehicle.
Titi
Post by Titi »
CIVIC home with the S300 do not run the streets. I have a problem that vtec engages more,about smanager is online I can go on high tables.quant the vtec was active I can not go on high tables they automatically return
Go to Options and uncheck tables follow VTEC.
Titi
Post by Titi »
ok! I'll do that as I have reassembled my engine. I'll let you know
Titi
Post by Titi »
hello, I have put my engine in my car, I went to the option as you told me and it fonctionne.thanks for your help.thank you very much
fonctionne = functions / works
Good.
