k20a2 I/H/E buddyclub spec 2 cams, rbc+karcept+70mm TB
EVLDC5
Post by EVLDC5 »
hi i have a dc5 type r with buddyclub spec 2 cams, I/H/E with rbc +70mm TB and injen CAI in need of a good tune, and AC/TEMP GAUGE not working,
help anyone?
Re: k20a2 I/H/E buddyclub spec 2 cams, rbc+karcept+70mm TB
In 'Parameters', enable the 'Multiplexor' setting.
EVLDC5
Post by EVLDC5 »
its already in "Normal" operation, Temp gauge works now, but still no a/C? i mean the ac clutch is not grounding, even the condenser fan not turning on, i need some help guys, its starting to get really hot here now,
Check the ECU is getting the signal from the AC ('ACSW' in sensors). If not, then the low pressure circuit might be preventing AC from engaging.
EVLDC5
Post by EVLDC5 »
Hondata wrote:Check the ECU is getting the signal from the AC ('ACSW' in sensors). If not, then the low pressure circuit might be preventing AC from engaging.
just checked, ACSW in sensor, ecu is not getting signal when ac switch is pressed on, what do you mean by the low pressure circuit?
and yea, when i press the ac switch, nothing happened, condensor fan dint turn on either, but when i ground the ac compressor clutch, it clicks in, btw car is a dc5 03 type r,
Look at the factory manual - a low / high pressure cut out protects the compressor.
EVLDC5
Post by EVLDC5 »
Hondata wrote:Look at the factory manual - a low / high pressure cut out protects the compressor.
so how do i fix it? please its really starting to get hot here in sydney,
Follow the trouble shooting steps in the helms manual.
