Map fuel tables and disable maf
Hybrid_Hatch
Post by Hybrid_Hatch »
hello.
If I run a hybrid afm calibration with map fuel tables enabled can I disable the afm? I am currently running a rsx iat and have deleted the afm all together. I see the "enable maf" in the software, can I just uncheck it? I have the car fully tuned but would like my fuel gauge to act normal and get my oil change minder back, can I just copy/paste my ignition and fuel values from my current tuned map calibration over to the afm calibration with all the other fuel related values and be good to go?
Re: Map fuel tables and disable AFM
Without know what car & calibration this, I can't answer the question.
If you are using an AFM calibration then the oil life should still be working.
Hybrid_Hatch
opps, my bad.
Car is a 08 civic si and I am currently on a street and dyno tuned Map only calibration, I street tuned the car for drivablity then put it on a dyno for WOT tuning.
what I want to do is transfer all of my values (fuel/ ignition/ over run/ cold start/ ect) over to a "new" AFM calibration and disable the AFM as its no longer installed on the car/engine.
Hybrid_Hatch
ok, so I tried it tonight...
I copied all my values over to a new afm cal, I did the fuel, ignition, vtc, over run, cold start, throttle, basically everything, took the car for a few spins while data logging and the car felt weaker, the a/f was the same weather using a afm or map cal and the ignition was the same but the car just didnt not feel anywhere hear as perky and almost stock feeling, I re loaded the Map cal and the car came back to life, so either I did something wrong or a map based cal is what the car wants.
The fuel tables are different between the race and normal calibrations.
Yes, you can remove the AFM and replace with an IAT.
