Autotune with fuel tables and AFM enabled
raymondclark0
Post by raymondclark0 »
Hello
ATM I have a stock civic fn2 with a flash pro, all I have done so far is loaded the group n calibraton and calibrated the AFM flow rates, if I enable the fuel tables + afm enabled and do an auto tune (for the fuel tables), will it make much of a difference to the power, throttle response etc vs the AFM enabled + tables disabled?
Also if I enable the fuel tables do I have to disable the AFM for it to work correctly?
Thanks,
Re: Autotune with fuel tables and AFM enabled
When properly tuned you should be able to get the same amount of power either way. It all depends on your tuning.
No you should not disable the AFM as it is still required.
