FlashPro V1.4.5 (beta)
V1.4.0 (5 November 2012)
  • FlashPro firmware updated to version 47
  • Added support for the 2012 Civic Si, 2013 ILX, 2007-2008 Fit.
  • [Traction Control] Firmware 6
  • [Traction Control] Don't start datalogging if the Traction Control is switched off (allows for burnouts).
  • [Civic Si / Type R] Added learned fuel trim under closed loop parameters.
V1.4.1 (26 November 2012)
  • Added CRZ & TSX calibrations.
  • Removed ECT2 as traction control input (too slow).
V1.4.2 (5 December 2012)
  • Fixed a problem with CRZ J05 calibrations loading into P02 ECUs
V1.4.3 (17 December 2012)
  • Added S2000 & CRZ calibrations
  • [S2000 - Euro/Asia]Fixed traction control not working.
V1.4.4 (11 Jan 2013)
  • TL support.
  • [Fit] Allow editing of fuel & ignition table indexes.
V1.4.5 (30 Jan 2013)
  • [S2000] Allow ELD to be disabled.
Nike
Re: FlashPro V1.4.0 (beta)
Post by Nike »
To Hondata:
1. May you will add function to the correct final drive?
2. When you will be speed adjustment to R18?
3.
Hondata wrote:1. We can add the injector use for fuel economy to the R18, like the Euro CTR, which may fix the problem.
Where is it?
P.S. Civic US R18 5MT 2006.
beaugus
Post by beaugus »
+1 For adding final drive correction option. Still waiting for this to become available for TSX Flashpro users to re-enable cruise control.
Edit; actually the ability to input custom gear ratios would be better in Australian Accord Euro owner's situations due to the slightly different ratios found on gears 1,3,4 and of course the final drive ratio.
Zoro2006
Post by Zoro2006 »
some guys started to use different gear ratios even in TSX, so it would be nice to have fields where we could imput ratios as it's in K-Pro for example.
Known as Vaikis_
BWelbourn
Re: FlashPro V1.4.1 (beta)
Post by BWelbourn »
Hello,
I just installed FlashPro Manager (FPM) 1.4.1.0 to my laptop. When I connect my FlashPro to my laptop, I get a message stating that the "FlashPro Firmware will be updated." I hit okay, the datalog light on my FlashPro lights up (amber color) and then my laptop displays the same firmware update message again. This process has repeated about 10 times so far and is still continuing. Is there something wrong with FPM 1.4.1.0? I did not have any problems with FPM 1.4.0.0.
Thank you,
Bill Welbourn, Ph.D.
Vehicle: 2012 Civic Si
FP Serial Number: FP-2012Si-110021
Running Windows 7 64-bit
juaniyo24
Post by juaniyo24 »
I have the same problem..as the post above ahhhhh....someone post 1.4.0
tj___90
Post by tj___90 »
The same problem as above with 1.4.1.0
nick3237
Post by nick3237 »
I am having the same issue wit the firmware update message. Anyway we can get Beta 1.4.0 back?
Sorry folks. Re-download and try again.
tj___90
Post by tj___90 »
Thanks its working fine now. asked me to update the flashpro firmwar once. All good now
BWelbourn
Post by BWelbourn »
Thank you. FlashPro Manager seems to be working properly.
VitViper
Post by VitViper »
The fit FlashPro seems to have an issue with the throttle -- MASSIVE delay when using FlashPro. I have a customer testing out the FlashPro on his 08 Fit auto and when trying the stock tuned calibration the car is basically undriveable due to a long throttle input response delay that is *not* there stock (I had him restore to stock and unlock the FlashPro to test). Attached are two logs.
.01 -- Stock tuned FlashPro calibration
.02 -- OEM Honda calibration with FlashPro unlocked.
Yes, we fixed that this afternoon. Re-download and install.
angelf1974
Post by angelf1974 »
beaugus wrote: Edit; actually the ability to input custom gear ratios would be better in Australian Accord Euro owner's situations due to the slightly different ratios found on gears 1,3,4 and of course the final drive ratio.
+1
Honda Accord CL9 (Spain)
RC51ManSam
Re: FlashPro V1.4.3 (beta)
Post by RC51ManSam »
Tried every way to install FlashPro Manager. Get this "Could not start application" "Failed (error0)".
