K-series wibeband oxygen sensor?
jostrom
Post by jostrom »
In the K-Pro introduction it's mentioned that the US and Japanese K series engines use a wideband front oxygen sensor. Does anyone know whether the Euro Civic Type-R (EP3) has one too? If it has one, is good/accurate enough to be used is dyno tuning the engine?
If the car does not have one, does K-Pro ECU support datalogging an extra lambda sensor?
The Euro Civic is a narrow band primary o2 sensor.
jostrom
Post by jostrom »
Ok. So there is no way to datalog a wideband lambda using a Euro-CTR ECU.
Does the RSX-S ECU work in a Euro-CTR? Are there any retailers that sell the RSX-S K-Pro and a RSX-S lambda sensor?
templeayb
Post by templeayb »
jostrom wrote:Ok. So there is no way to datalog a wideband lambda using a Euro-CTR ECU.
i have euro ctr as you . i'm going to get kpro with new prb ecu. after i installed it i write her my comments
destroked K24a / K20a head
