I probably need a new map or need advice for my actual
olivenoire
Post by olivenoire »
Hello
A tuner tune my car with this kind of map.
I'm really not happy with it, because I have knock and vtc is dissabled
I run an Eu EP3 2005 with turboed k20
Can someone able to give me some advice?
Can I put more gaz? less advance?
Can I activate the vtc??
My setup :
K20 with 9:1 forged piston and eagle rod
Eu ecu with Kpro
Turbo kkk k24 with full 3" exhaust
Can I use a PRB setup???
When I try the EU setup in kmanager (With Jackson, the motor stop when the turbo is charging) -> probably lean protection...
I need some help.
Thank you in advance
EDIT
About the base map...
After trying a jackson eu setup I'm afraid to do a mistake...
I do not own a wide band too...
May i test a RSX-PRB setup??
For exemple a greedy or revhard setup??? I mean with my PRA ecu???
Ep3 eudm
K20a turbo
Kpro v4
The unwanted AEM 30.4100 WB AFR
Re: I probably need a new map or need advice for my actual
Since you are unsure of what you are doing and have no wideband you will need to take this to a tuner to have it properly tuned on the dyno.
olivenoire
You are right
I've contact a tuner near me and he only got a base map for compressor, not turbo
It is really difficult for us in europe understand if we can put a wideband and log with our PRA edu...
I'm going to buy a wide band... And I cant log, I will be ablt to make direct view
So sorry to do not have a map...
Ep3 eudm
K20a turbo
Kpro v4
