Drag car settings
Drag car settings
After extensive testing (we rented a track) here are Traction Control settings for a drag car.
SManager & KManager settings will be the same:
The test car was a Turbocharged K-Series EG Civic with 8.5" slicks. Best launch was with the TC switch on the 2nd or 3rd click (clockwise from off).
Bard
Re: Drag car settings
Post by Bard »
Hello guys. Can you please post a video results of a drag race on 402 meters with traction enabled and disabled, with numbers please. Or might there are some papers with results? And if there were some different settings can you also post em!
Thanks! Anxious on results!
sass
Post by sass »
Bard
+1
Cr-v RD8+K24A2turbo+Kpro V4 prb+NPR3/6Speed+ТС+ HFS4 v3.2.
DynoWheel = 472kW / 589 N.m
HRX One Mile Challenge = Max Speed 282km
Known as Sniper
Bard
Post by Bard »
no proof that it really helps ?
Please, no trolling.
It works very well for drag cars.
It is difficult to provide the information you request as that would require multiple back to back runs with the same car in the same lane of a drag strip on the same day. Events typically do not provide this testing environment; also it is winter and there are no events here for another couple of months.
stlegal
Post by stlegal »
sorry no one can tune hondata traction control .without traction control better..
http://honda-tech.com/showthread.php?t=3128999
Many people have traction control working well. If you have having trouble post the details here and we will try to help.
stlegal
Post by stlegal »
can you add program menu traction control for maximum speed ??
What exactly are you asking? A speed limiter?
stlegal
Post by stlegal »
Yes speed limiter.for example at 150 km/h or 3th can i disable traction control?
A speed limiter or the maximum operational speed for traction control?
The answer to the first case would be that traction control is not the correct place for a speed limiter.
The answer to the second case is why would you want the traction control to have a maximum speed? We've run it over 200 mph without any problems.
stlegal
Post by stlegal »
aem has User Definable Traction Units: On/Off TC Speed On/Off
motec has User Definable Traction Units: On/Off TC Speed On/Off
hydra has User Definable Traction Units: On/Off TC Speed On/Off
hondata says :" The answer to the first case would be that traction control is not the correct place for a speed limiter .The answer to the second case is why would you want the traction control to have a maximum speed? We've run it over 200 mph without any problems.".
thank you sir go ahead!!
I'm not sure if this is part of a turing test or not.
If you make a good case for the need to disable traction control then I'll add that feature.
stlegal
Post by stlegal »
Hondata wrote:I'm not sure if this is part of a turing test or not.
I want to make sure that the traction off top gears..for example, enough to work with the first and second gears for drag.Wheelspin is not always slowing my car down. Compared to being able to fully accelerate with 100% grip, yes i am losing a little speed, but even when the wheels are spinning, the car is still accelerating.
stlegal
Post by stlegal »
