Urgent matter - protect the ECU
olivenoire
Post by olivenoire »
Hi
Tomorrow I will put the car to the garage
Because of my higly modified motor, low temperature (winter), I want to protect my car against somebody for him not able to drive more that 4500rpm
Okay easy to set.
But if I protect the ECU, to prevent download , upload of modifying. Can I revert?
I've set password but dont know the effect. Seems not enough
Any help would be much appreciated!!!
Thank you
Ep3 eudm
K20a turbo
Kpro v4
The unwanted AEM 30.4100 WB AFR
Re: Urgent matter - protect the ECU
Unless they know they password they will not be able to upload.
If you don't want someone driving your car then just remove the ECU and take it with you.
olivenoire
OKay I understand.
So password is enough, I don't need to use the "protect ecu"
They will need to move the car and start the engine, I'm going made make a custom manifold and full exhaust 76mm
Thank you
Ep3 eudm
K20a turbo
Kpro v4
