Copy&Paste in the lambda and sensor overlays
zbrskz
Post by zbrskz »
Hi Hondata, Spunkster,
When trying to copy the lambda or sensor overlay values the fuel table values are pasted instead of the displayed lambda or sensor values.
Could you please implement copy&past for the lambda and sensor overlays in the Hondata versions to come?
Thanks,
Luis Fernandes
zbrskz
Re: Copy&Paste in the lambda and sensor overlays
Post by zbrskz »
A reply for the above request would be deeply appreciated.
Thank you,
Luis
It is intentional that the underlying fuel table values are copied / pasted.
zbrskz
Post by zbrskz »
We can copy the fuel values from the normal fuel table (SHIFT+F3).
But copying the same underlying fuel table values when in lambda overlay (SHIFT+F4) leaves no option to copy the intended lambda values.
Lambda values, for instance, are of great importance for a correct tuning. It is frustrating to have to copy "by hand" a 10x20 lambda table to excel, as an example.
There should be a way of allowing the user to copy the displayed lambda or overlay values.
Thanks,
Luis
