Datalog download: no files
zbrskz
Post by zbrskz »
Hi,
We are currently racing with four 2004 Euro Civic Type-R (EP3). All have the standard PRA ECU. Three have 1st generation KPROs, and one has the lateste KPRO III.
We use a single PC to upload calibrations and download datalog files. Ocasionally, when trying to download the race datalogs no files are displayed for download, even though datalog memory is full.
Any advice?
Luis Fernandes
Re: Datalog download: no files
We need serial numbers as well as the version of software from Help, About.
zbrskz
Post by zbrskz »
The version of KManager is the latest, 3.1.6.0.
I'll get you the serial #s as soon as I have it.
zbrskz
Post by zbrskz »
Spunkster,
The KPro's serial #s are: 7586, 7909, 9721 and 10085.
I've attached full KPro info print shots.
Last race, only one out of the 4 ECUs made files available for download, all other 3 had memory full but no files to download. I've also attached one print screen of this problem.
Luis
Download the most recent beta version of software from the downloads section of the website then make sure you upload the calibration using the new version to all ECUs in question. THen clear the datalogging memory and see if that resolves the issue.
zbrskz
Post by zbrskz »
Spunkster,
Last race I've in fact upgraded to V 3.1.6.
All ECUs had their respective calibrations uploaded, and their datalogging memory had been cleared more than once during the weekend (before saturday practice, before qualifying, before sunday practice and after race #1).
I'm not to fond on using beta versions on race weekends, but I'll give it a go as suggested.
Thanks,
Luis
turbodav
Post by turbodav »
im having the same issue but mine was fine up until the 3.2.0 then it would datalog but it would say it is full but there would be no files shown ive got the latest software in it now but still having the same issue using the same laptop and cable ive used all year btw im on kpro3.
also i have a friend that races with me in nasa he is in honda challenge 1 he has the same problem with his after the same updates he on kpro with k24 with his same laptop and cable he has used all year as well
turbodav
Post by turbodav »
anyone else having any problems with the on-board dataloging
We have been able to reproduce this. It should be corrected in the next release of software.
You can always reduce the frequency that it datalogs at and it will not completely fill the memory and then you will still be able to download the file.
turbodav
Post by turbodav »
It shows no file but full on memory where can you find the file at to download
You must erase all datalogs and then change the frequency so that it does not fill the memory.
turbodav
Post by turbodav »
any idea when the update will be out to fix this issue?
The beta version has been updated (V3.2.1) to fix this problem.
