ep3dem1k
Posts: 9 Joined: Tue May 25, 2004 2:15 am
Post
by ep3dem1k » Tue May 25, 2004 2:21 am
I have a K-pro in my 04 EP3(USDM SI) and I have a K20a(RSX Type-R) motor. When I start my motor and the motor is cold and if i let the car idle the check engine light will turn on after a few minutes, its a soft code because when i hook up my laptop and try to read the code it does not show up. If I turn the ignition off and turn it back on the check engine light turns off. Do you know what may be causing the light to turn on?
Posts: 10665 Joined: Thu Aug 15, 2002 12:13 pm
Post
by Hondata » Tue May 25, 2004 1:01 pm
Do you have the stock cat? If not then it is likely the MIL is from the secondary o2 sensor. Disable error P0134 and see it the MIL goes away.
ep3dem1k
Post
by ep3dem1k » Tue May 25, 2004 8:49 pm
I datalogged the car and it threw a unknown code 77. Do you know what a "unknown code 77" is? That is the code thats been setting off my MIL.
David
Post
by Hondata » Wed May 26, 2004 8:24 am
The error code is related to the cat & o2 sensors.
Do you have both o2 sensors and a cat? If not then you'll need to disable the OBDII functions in KManager.7
ep3dem1k
Post
by ep3dem1k » Wed May 26, 2004 12:15 pm
obd2 has been disabled and I still get that code
Post
by Hondata » Wed May 26, 2004 10:14 pm
For the love of god, answer the question:
Do you have the stock car and how many o2 sensors are there?
ep3dem1k
Post
by ep3dem1k » Wed May 26, 2004 10:30 pm
I have no cat and I have both O2 sensors plugged in.
Post
by Hondata » Thu May 27, 2004 9:08 am
In KManager disable OBDII and error P0134.
If you still get a MIL then jumper the OBDII connector and tell us the code from the number of MIL flashes plus the DTC from KManager.
To jumper the OBDII connector short out pins 4 & 9 with a paper clip. The MIL should start to flash the codes.
ep3dem1k
Post
by ep3dem1k » Thu May 27, 2004 2:16 pm
I'm throwing a code 41
Post
by Hondata » Fri May 28, 2004 5:44 pm
41 = Air Fuel Ratio Sensor Heater System Malfunction
We'll update KManager to show the correct error code in the next release.
Does KManager still show unknown error 77?
Which error codes have you disabled in KManager?
Are you sure the o2 sensor wiring is working OK? Have you followed the troubleshooting procedure in the manual?
ep3dem1k
Post
by ep3dem1k » Fri May 28, 2004 10:30 pm
My KPro reads "unknown code 77" When I put my motor in I did not cut any part of my harness so it should all be good. I'm going to try to replace my frint o2 sensor. The MIL will still go off even if I turn the o2 sensor heater off from the kpro.
ep3dem1k
Post
by ep3dem1k » Sat May 29, 2004 11:20 pm
I replaced the front o2 sensor today and it still does the same thing "unknown code 77" and if i jump the obd2 service connector its code 41.
