Will K-pro RSX-S ECU work in an Element?
silum
Post by silum »
I was wondering if I got an Element and a swapped in the head and ECU from an RSX type S, would there be any issues? I would think the engine would be fine but what about multiplexer stuff (if any)? Any other 'gotchas'?
Hondata Stage 4BD
USDM 1995 Civic Si (EH)
D16Z6, 1.6L SOHC VTEC
Apex-i BB AX Turbo w/ GT I/C & AVC-R II
440cc RC Injectors
Walbro 255LPH HP Pump
B&M Command-Flo
Jun UltraLW Flywheel
ACT Clutch
Quaife LSD
SRP Pistons (Stock C/R)
Crower Rods
We don't know if the programmable ECU would work in the Element. You'd need to compare the ECU wiring for the Element and RSX, then see what the differences are.
