?JDM P73 speed limiter removal?
pythonscott
Post by pythonscott »
:D Is it possible to remove just the 200kph (125mph) speed limiter from the JDM P73 Type R ecu? I'll be installing an ATS FD soon and know that on many road course tracks I'll be running into the limiter on the long straights. I know that any limiters are removed when Hondata is added to an ecu, but all I'd like done for now is the top speed limter.
team-integra.net Moderator
Hondata does not work on OBD2 ecus. You willl have to convert to OBD1 and then you can use a Hondata system.
pythonscott
I know that hondata SYSTEMS don't work for obd2... what I'd like to know is if Hondata can remove just the speed limiter from the ecu. Surely Hondata knows the piece that needs to be altered/removed to do this.
Hondata does not work on or modify OBD2 ecus.
pythonscott
thank you. :) can you point me in the direction of someone that can do what I'm looking for?
