Additional Autotune Settings?
Dan1987
Post by Dan1987 »
Would it be possible to have the option to configure AutoTune so that it will make changes dependant on number of samples taken at each cell (and averaging) rather than once per time period (1 second default)? (I am not sure if it currently takes the sample rate determined in lambda overlay settings into account at the moment or not?) Also would it be possible to include an option to display in the sensor overlay table the number of samples taken at each cell during a data-log? This would allow us to determine which areas we spend most of our time whilst driving and allow us to increase column/row resolution in these areas for finer tuning in these locations.
Many thanks,
Daniel
Re: Additional Autotune Settings?
Yes, it would be possible to use a number of samples rather than the time delay for each change.
The sensor overlay mouse over shows the number of samples.
Dan1987
Post by Dan1987 »
Thanks,
So does it take the mean value from those samples and apply it or does it just take the value from the final sample of the sequence?
It uses the mean.
