From 750cc to 1000cc
Steeve_Civic
Post by Steeve_Civic »
I would like to change my injectors to 1000cc.
Is there somewhere in S300 to adapt the map please?
Re: From 750cc to 1000cc
Parameters, Fuel Trim.
Steeve_Civic
OK but that doesn't change the fuel tables numbers ??
fuel trim changes do not change the table values
Steeve_Civic
ok I will try, but still do not understand.
Could you explain me why it doen't change the fuel table? Fuel table isn't the injector opening time?
Steeve_Civic
Do you know the explications?
mtber
Post by mtber »
Steeve_Civic wrote:ok I will try, but still do not understand.
Changing the injector size will change the fuel multiplier & leave the fuel table values the same.
The easiest explanation is that the software uses this to calculate how much fuel to inject on all of the global fuel values.
To learn how to adjust your injector fuel trims read: http://www.hondata.com/help/smanager/in ... eltrim.htm
http://www.phearable.net
Phearable.net - Hondata Authorized Dealer
