help with stock calibration
2007-2008 Fit
08_Fiji_Fit
Post by 08_Fiji_Fit »
hello i have a 2008 honda fit sport automatic and i just got my flashpro today and i locked it to my vehicle with no problem but when i installed the stock base calibration i ran into a problem. After i flashed it i turned the car on and when i stepped on the gas i get no response. i have to fully step on the gas pedal all the way down for the rpm's to even move.
I also loaded the stock calibration for the 07 fit sport with that one installed the car responds fine but i cant get it out park wtf!!!!!
i need help on whats happening here.
PLEASE look at the datalog i made on what i mean i press the gas pedal and no response.
Re: help with stock calibration
It sounds like a MT calibration in the AT vehicle. First re-download and install FlashProManager from http://www.hondata.com/forum/viewtopic.php?f=29&t=14780. Make sure that your FlashPro is plugged in the first time you open the calibration, then it should select the AT calibration.
08_Fiji_Fit
Going to try that out
08_Fiji_Fit
ok just did what you said and nothing same problem accours.
Later this afternoon you should be able to redownload the software and install it and that should resolve the issue.
08_Fiji_Fit
sweet thank you
You should now be able to redownload the beta version of software from the downloads section of the website, install it, and it should work.
08_Fiji_Fit
I'm currently at work I will try again tomorrow morning.
08_Fiji_Fit
now its working right thank you hondata
