D16z6 swap, Crank angle sensor issue
MayberrySS
Post by MayberrySS »
The conditions of the issue:
It seems pretty consistent that the load of the engine in 3rd gear (gear it does it in doesn't matter) at 5,500 rpms while in v-tec, car will misfire then go into limp mode, but not all the time. Almost intermittently.
What I have done so far to try and fix the issue:
The computer was replaced with another (P28), same tune (eliminated the possibility of a bad ECU). The distributor is brand new. (Third distributor in the car, 2 used ones and now currently the new one.) New NGK plugs gap at .044 and new plug wires, wiring harness between the dizzy and ECU have been re-done with new wires and pins as well to see if it fixed this issue. Anyone think that the timing belt could be off a tooth?
I got code 4 CKP - crank position sensor and code 17- VSS (my speedo cable is broken so that is obviously not an issue)
Here is a video of what is happening.
https://www.youtube.com/watch?v=qoXrf3c ... ata_player
Thanks for looking.
Re: D16z6 swap, Crank angle sensor issue
Check the ground at the thermostat housing.
MayberrySS
Will do thanks!
