S300 problems
Monnoracing
S300 problems
Post by Monnoracing »
I dont have the numbers for you at the moment. Ecu has been working for the last 2 years, then tonight it decides to almost act like certain files are corrupt and immediately triggers a CEL. My thought is the new security feature having something to do with it.
Monnoracing
Re: S300 problems
yep it just picks and chooses when it wants to shut down
Re: S300 problems
Switch off the ignition, shut down SManager, restart SManager and then re-upload the calibration.
Monnoracing
Re: S300 problems
That allowed me to load the tunes that were not. Why all of a sudden would it start doing this? I have jumped from file to file while the car has been running before and no problems.
Re: S300 problems
Any time you completely change a calibratio you should close and reopen the software or you will end up with a corrupted calibration. IT has always been this way.
Monnoracing
Re: S300 problems
It may have always been this way but something has happened since last update. I have had the car die when changing from file to file but that has been 2 times ever.
Monnoracing
Re: S300 problems
And when that happened I just had to restart the car not close down everything and I had no CEL with no code.
Monnoracing
Re: S300 problems
- s300-0886
- 90 civic si
- 37820-p28-a52
- wideband input and nitrous 1 output to relay
- Unable to upload files now or atleast no longer shows a progress bar. When it will start runs rich and main sign of a problem when the s300 is plugged up the main relay clicks its 2 times but very fast. With my other ecu it clicks 2 times with a pause between like normal. Any ideas? Also on my way home just upped and started running rich and had to be towed home.
Re: S300 problems
Go to Online, and click Erase ECU. THen that finishes, close the program and reopen it m then upload a fresh calibration from File new. Does that work?
Monnoracing
Re: S300 problems
I tried that Spunkster with no luck. The red led inside is on solid and the green blinks every 10 sec. I am using a friends ecu right now with no problems. I was going to install my s300 chip in his ecu and see if its my ecu. If its the s300 chip what actions do I need to take to get this fixed?
Monnoracing
Re: S300 problems
Here is a screen shot of the failed notice when I am trying to setup the newest beta version or any of the versions now. Even after this failure happens s manager opens and I can work the other computer. I was able to download the file that was currently on the chip and it was not my file. I am going to use a different laptop tonight and see what happens,
Re: S300 problems
If that does not work, let us know here and then send an email to support <at> hondata.com with the following and I will issue an RMA and give you further
instructions (include a link to this thread):
Name:
Address:
Phone:
Email:
Serial#:
Brief Description of Problem:
Monnoracing
Re: S300 problems
Will do. Thanks
Monnoracing
Re: S300 problems
No luck with dl the latest version and erasing the ecu. I am still getting a upload error and a solid red led on.
Re: S300 problems
Have you sent this in yet?
