Normal error codes for TSX KPro Dual adapter setup?
evenq
Post by evenq »
I'm running the old KPro Dual ECU setup on my 2005 TSX and recently hooked up the obdii to the KPro. Is it normal for this setup to be showing these 2 codes? P0453 - EVAP FTP Sensor High Input and P0505 - Idle Air control System. From what I understand the stock TSX ECU still controls idle. I know I can un-check "Enable emissions error checking" to get rid of the codes but if any of these codes are valid with this setup I would like to work on getting it resolved.
Thanks.
Re: Normal error codes for TSX KPro Dual adapter setup?
The TSX ECU is what communicates to the OBD2 diagnostics port.
This setup is no longer supported, unfortunatley we cannot try to troubleshoot this. You would be much better off using the FlashPro for this vehicle.
evenq
Post by evenq »
I understand FlashPro would be the best option here in the long run but I want to know if the sensors like FTP and whatever sensor is causing the Idle Air Control System codes to come on is even connected to KPro or is it handle by the stock TSX ECU. Basically is the FTP sensor passed on to KPro via the harness or is it still on the stock ECU?
