Need to wire Wideband signal and tractioncontrol unit signal
megaracing
Post by megaracing »
I need to wire the output of my innovate mtx-l Wideband output and the output of the hondata traction control unit to my p28 ecu which is chipped by ha motorsports with the s300 v2! The instructions for the Wideband and traction control says to use the d10 eld pin to wire the signal! I understand that I cannot connect both the wires to the same pin! How do I connect Wideband signal and the traction control signal to the ecu? I need to use Wideband closed loop control and traction control in my race car!
Re: Need to wire Wideband signal and tractioncontrol unit si
Your available inputs for the wideband and traction control are O2, ELD, D12 & B6, so you can wire both in.
megaracing
Hondata wrote:Your available inputs for the wideband and traction control are O2, ELD, D12 & B6, so you can wire both in.
Does the d12 and b6 support 0-5v inputs? Do I need to change any capacitors and resistors?
I would like to connect a switch to b6 to make the data logging controlled by a switch!
Now how do I make all the three options work? I'm gonna build a mil spec custom harness from Ryan of rywire! So I would like to clarify everything!
http://www.hondata.com/help/smanager/an ... ghtsub=d12
http://www.hondata.com/help/smanager/an ... sub=analog
D6 is not an input used by onboard datalogging. You must use one of the inputs listed on the On-Board Datalogging tab.
megaracing
Spunkster wrote:http://www.hondata.com/help/smanager/an ... ghtsub=d12
Thank you very much for the reply! It was of great help!
Can you suggest me what are all the options that I can use in the s300 for my na d16y8 race car!
If you look at the software you can see all the options there.
