ect sensor
200HP EP
ect sensor
Post by 200HP EP »
Why ect 2 sensor is disable with flashpro calibration?
Re: ect sensor
Why would you disable the ECT2 or why is the ECT2 sensor disabled in a calibration?
200HP EP
Re: ect sensor
Post by 200HP EP »
Maybe it is ECT1... Anyway. When Honda dealer plug his scan tool, they dont see any data from one of the two ECT sensors. Is it normal? When I upload "back to stock" calibration, they are able to read data from both ECT sensors.
Re: ect sensor
Please post your calibration
200HP EP
Re: ect sensor
Post by 200HP EP »
here is my calibration
final calibration.fpcal
Edit. When I look at my calibration, in "misc parameters" , second ECT sensor is disable. Is it normal or it has to be enable. In what circumstances you disable that sensor?
Re: ect sensor
It is a race calibration and also the ECT2 sensor is disabled.
200HP EP
Re: ect sensor
Post by 200HP EP »
Ah! Ok! Why ECT2 is disable in race cal?
Nazul
Re: ect sensor
Post by Nazul »
Lmao, why do you upload a race cal? u must be out of ure mind, you can thank god your engine is still runnig fine
200HP EP
Re: ect sensor
Post by 200HP EP »
Why you said that? My car run with this map calibration since 4 years. Not sure of what you mean!
Nazul
Re: ect sensor
Post by Nazul »
Well yeah did anyone ever tune the engine and test the AFR for not running too lean or rich?
200HP EP
Re: ect sensor
Post by 200HP EP »
My engine have been tuned since the first day with this cal.
Nazul
Re: ect sensor
Post by Nazul »
That was not my question, I asked on a dyno with AFR measurements or not?
200HP EP
Re: ect sensor
Post by 200HP EP »
Forget it!
