Race Header With Reflash
Danieliyo
Post by Danieliyo »
Hey,
I seen people saying that Race Header and Reflash makes the car run lean. But I see that only happens with 05-06 RSX Type S. So for 02-04 RSX Type S Race header & reflash is safe to run? will it run rich?
If anybody can answer my question,I would appreciate it. Im confuse
Re: Race Header With Reflash
With any reflash a race header will run lean. To find out how lean, you would have to dyno the vehicle. For this reason we recommend the KPro for use with a race header. Also be aware while it might run lean, it is not going to be any leaner than using a stock ecu.
