06-08 TSX and VTC
05typeR
06-08 TSX and VTC
Post by 05typeR »
Ok guys seeing these cams are bigger on the intake high side in both lift ad duration and bigger primaries on the exhaust side my question is: using these cams on a K20A2 internally stock motor will I be able to safely reuse my VTC gear up to 50 degrees without any contact?
Re: 06-08 TSX and VTC
You will have to clay the motor to make sure it is safe.
