issues with the digital sensor setup
jbaker
Post by jbaker »
I have the latest Kpro III and updated software. I'm installing an additional O2 port for wideband monitoring. I'm installing the PLX SM-AFR and used a DIY from the s2ki forums:
http://www.s2ki.com/s2000/topic/952240- ... ry21699427
My issue is that I cannot setup my digital sensor. In the parameters window, I can input the channel type, name, unit. However, when I goto options...sensors and select the DI0, it does not have any of the information I just input in the parameters window. The units are in volts and did not update the name etc.
Am I missing something? I do not have the laptop plugged into the ECU but didn't think it was necessary to setup it up in the software and groom my display templates etc.
Thanks in advance!
...edit...
In parameters I have the units as air/fuel ratio but in sensor setup it has it in volts and will not allow me to change the units.
Re: issues with the digital sensor setup
You need to uplaod the calibration with the Digital Input settings you want then you will be able to datalog and set the sensor window correctly.
