AEM Uego installation Kpro 2
pdapaul
Post by pdapaul »
Morning,
Please can someone advise or point me in right directions for pin location and setting up of AEM Uego on:
2003 UKDM civic type r
Kpro 2
I know I can't use it for tuning, I just want to data log.
Many thanks
Paul
pdapaul
Re: AEM Uego installation Kpro 2
Post by pdapaul »
Cheers
Lets go data logging !!!!
pdapaul
Post by pdapaul »
Morning,
I've entered the info given by AEM and I still can't calibrate the AFR. Even when is use the offset its still way out.
Can anyone advise further please?
If this I'd going to be an issue is there a plug & play afr that will work correctly with kpro
Cheers
Paul
We have seen a lot of people have issues with the AEM gauges. We recommend the PLX Devices widebands.
pdapaul
Post by pdapaul »
If I get a plx wideband (such as SM-AMR gen 2) will it still require calibration, it are the kpro settings sufficient?
Thanks again for your help
Using an analog nput will always require you to input the calibration info and a voltage offset to read accurately.
