New Asus laptop - S300,Kpro or Flash pro will not load.
ALL M0T0R
Post by ALL M0T0R »
I keep getting Failed (error 0).
AV is Webroot, i'm assuming this has to do with some type of coding you guys use on your programs.
I have a few customers i'm trying to tune tomorrow and trying to update to the beta versions of the programs and now they wont open.
Tried running in a different mode, and also tried running as admin. Why does this program happen and i know i'm not the only one. I would figure out why this is happening and change whatever is setting off AV's.
DDTECH
DDTECHCAMS.com
Re: New Asus laptop - S300,Kpro or Flash pro will not load.
Sometimes adding the directory to the AV exception list works. See http://www.hondata.com/forum/viewtopic.php?f=1&t=8240
Uninstall the antivirus software and it should work.
