column10 ?
FlashPro questions & answers specific to the 2010 CR-Z (US, Euro & Asia)
alollini
column10 ?
Post by alollini »
my datalogs show that the car never goes into column 10
why ?
is it a problem ?
my altitudes of datalogs range from sea level to 500 meter altitude.
Team CR-Z Youtube Videos here => http://www.youtube.com/playlist?list=PL127E8C02C6B25D4B&feature=plcp
CR-Z GT White "Blue Inside"
Re: column10 ?
ITs not a problem, but at sea level it should read in column to unless you have a restrictive intake.
alollini
Re: column10 ?
Post by alollini »
yes, i see it's dirty, i'll change it as soon as possible.
alollini
Re: column10 ?
Post by alollini »
I tried changing filter element first (150mm HKS).
Modified intake to larger 200mm HKS bowl. <= current configuration
Even tried retrofit the stock intake with new filter element.
I still never go into column 10. columns headers seem to be bogus
what can be the cause ? is there a restrictor in the HKS RSR ?
can you point me to manual page where i can make the columns header display right ?
Re: column10 ?
The table index is working correctly (it is not 'bogus'). Your MAP sensor is not reading above column 9 (around 96 kPa) for whatever reason - production tolerances, intake restriction, altitude etc.
There is no reason why the ECU should read into column 10 when running. If you really want to use more columns, edit the indexes so they are lower.
alollini
Re: column10 ?
Post by alollini »
Thanks for the answer.
the display of the table header looks strange, but i guess there is no bug in the internal.
it displays fancy "0,2ps"
