input method?
aceman187443
input method?
Post by aceman187443 »
I am using a stock p28 map, that is a map for a 1.6 litre engine and my engine is a 2.3 litre. When asked "displacement" i would input the equivalent of in cc the the 1.6litre engine under old and under new i would put the cc equivalent of my 2.3 litre engine, correct?
Re: input method?
correct
balbowskie187
Re: input method?
Post by balbowskie187 »
What if the ecu is a p06 and you load a stock p28 map. You have a 2.3 litre engine. The p06 ecu matches a 1.5 litre (1500cc) and the p28 basemap matches a 1.6 litre (1606cc) engine. What is the old cc? New cc is of course the 2.3 (2295cc).
Re: input method?
The ECU does not matter. IT all depends on the calibration you load.
