Is a new tune needed?
s2kcrick
Post by s2kcrick »
I currently have the Vortech SC kit with Hondata reflash on my 08 S2K. I am thinking of getting an aftermarket header and test pipe and wanted to know if I need a new tune or will the existing tune for the SC kit will work with these new parts.
After this, I might also start looking into getting a smaller pulley for more boost.
What do I need to do for both scenarios?
Re: Is a new tune needed?
You would need the FlashPro to be able to tune this properly.
s2kcrick
Post by s2kcrick »
Does that apply for both scenarios or do I need FlashPro only for when I change the pulley for more boost?
To make sure it is running safely and not too lean you need the FlashPro to properly tune it whenever changes are made.
