launch soft
9queSt
launch soft
Post by 9queSt »
what does Launch soft do?
Will it increase EGT or have any harmful effects?
Re: launch soft
From the help file:
Soft Limiter
The soft limiter uses a progressive cylinder cut method to reduce engine power when near the launch limiter.
It is recommended to set the soft limit activation 50-200 rpm below the launch limit, and set the slider to about 75%
It is no more harmful than other rev limits.
SPOOLIN
Re: launch soft
Post by SPOOLIN »
what is the purpose of the soft limiter?
www.MSSRACING.com
9.29 | 6.20 | 167
Re: launch soft
it creates a more stable rev limit (less fluctuating)
