MIL on without codes with SCS jumper
rafael_vti
Post by rafael_vti »
Hello,
I received my new S300 and I'm having a behavior that I would like to confirm if it's correct and if it's not, how to fix.
I can connect to the hondata, upload calibration, datalog, and the car runs fine.
The isse is that when I put a jumper in the service connector and turn the car ON, the MIL light stays ON all the time, is that correct?
Infos:
Hondata S300 v2
Serial #s300 - 22307
SManager 2.2.4.0
1993 honda civic N/A
P28 ECU
Thanks in advance
Re: MIL on without codes with SCS jumper
This is normal
rafael_vti
Thanks for your reply Spunkster!
So it means that the behavior of the MIL light when you have a s300 is different of the stock ECU when you jumper the SCS?
Because with the stock ECU, if you jumper the SCS (and don't have any error) the MIL light stays OFF!
Best Regards,
Rafael
