Mtx-L innovate
dneilmotorsports
Mtx-L innovate
Post by dneilmotorsports »
can anyone show me how to wire the wideband MTX using analog input on s300 V2?
Please help...Tq..
Re: Mtx-L innovate
http://www.hondata.com/help/smanager/an ... sub=analog
You will have to look at the instructions that came withyoru wideband for specifics pertaining to your wideband.
dneilmotorsports
Re: Mtx-L innovate
ok tq..sir, but the MTX-L dont hve a ground wire.So, V2 ground wire where should i connect it..
Re: Mtx-L innovate
Did you read the second link?
dneilmotorsports
Re: Mtx-L innovate
yes i do.. But it not accurate, my MTX-L show 14.9 and my laptop show 18.++ AFR
Luke
Re: Mtx-L innovate
Post by Luke »
use a proper ground for the MTX-L and wire it good. if there are some differences, you can manage it with the offset voltage.
and check if the MTX-L is programmed right.
mitsuman
Re: Mtx-L innovate
Post by mitsuman »
