Wide Band O2 pin out connection EDM ecu
egracing
Post by egracing »
Hi all
I've a trouble to connect external o2 sensor to ecu, pin dedicated for egr in not usefull (condenser issue and edm has not egr but air pump)
connection to eld pin doesn't work and the same to eng temp pin (strange but E1 ecu pin is used but car is not equipped with second engine
temperature sensor) in any case i can't read a reasonable value for external o2 sensor.
I'm using an aem wide band throught white pin checked and it works.
many thanks for help
Re: Wide Band O2 pin out connection EDM ecu
Can you pleae tell us exactly how you have it wired, post your calibration and a datalog showign the problem.
egracing
Post by egracing »
Spunkster wrote:Can you pleae tell us exactly how you have it wired, post your calibration and a datalog showign the problem.
I've replaced pin E1 (dedicated to egt2), attached calibration and log
thks
From HElp, About, what version of software are you using (include time and date)?
egracing
Post by egracing »
Spunkster wrote:From HElp, About, what version of software are you using (include time and date)?
When datalag was done , sw was 1.4.2.0, and I chcked al pin possibility (egr,eld,egt2), now car and map run
with 1.4.4.0
egracing
Post by egracing »
with 1.4.4.0
Hi
little update , I've connect o2 wb sensor to pin E15 (eld) now i can see a value correct
but i don't know what it will happen with obd dtc, so why can't disable eld from flashpro ?
Why pin E1 it doesn't work for o2sensor input as well ?
Many thanks
egracing
Post by egracing »
Update 1.4.5 _ Great job hondata guys
so i'll check what happen after disable ELD
thks
deibit
Post by deibit »
Hi,
did it work?
I also want to connect a external wideband to a EDM S2000 ECU.
Before I try all available Pins, I would like to know what's the one supposed to work :) :)
Thanks!!
