Reflash Check...
Cheep3
Reflash Check...
Post by Cheep3 »
Hi, I just want to check on ECU #37820-PNF-A05 601163-2810. Thanks! Also, any chance of the ep3 reflash going on sale soon?
Re: Reflash Check...
This ECU has not been reflashed.
Cheep3
Post by Cheep3 »
Thanks, I'll be sending it through Clubep3 soon. Any chance of a price reduction to match the K-Pro's current new reduction??
No, the reflash price will not be changing.
Cheep3
Post by Cheep3 »
Just a heads up - my ECU (A05) donor, is on its way to Matt! Club RSX - K Series Parts is vendor (Order #140020). It should be there by 10:30 am Tues. 4/23/13. Do you think there's any chance they can flash and send it in the same day? Can't wait! Thanks, RH
It all depends on when it is received. The turn around for a reflash is 1-2 days.
Cheep3
Post by Cheep3 »
Well I just got a call from Matt at Hondata and I'm extremely disappointed both with Hondata and Club RSX the vendor I purchased the reflash from. It turns out they cannot reflash the ECU I sent in with my key and immobilizer after I just spent another $90 to overnight everything... Nowhere in anyone's info does it say that the immobilizer and key and ecu must be working in a car before they are sent in. I made it clear to Kseries Parts that it was a "donor" ecu. My only option again appears to be K- Pro... Hondata (and vendors) really needs to make this more clear for 05 si owners.
Nazul
Post by Nazul »
I believe they need to make a lot more clear yes, this is the second thing i hear right now.
