P28 or P75 for Ls/T?
pissedoffsol
Post by pissedoffsol »
Hey guys... couple questions for you.
I own a 94 del sol si (d16z6) and i am planning on an LS/turbo set up. My question is, Which ECU should I use for the hondata, the p28 or the p75? I own both already, both are obd1, both plug right in, and both will run my car. But which is better, after being 'chipped' by the s200 system?
Thanks for any input.
Brian@hondaswap.com
Brian@hondaswap.com
http://www.hondaswap.com
Hardcore Tech and Swap Info
idgeek
Post by idgeek »
This is a great question. I've 92 Civic CX and building a B18B turbo myself. I also have 98 GS-R transmission mated to that motor. What ECU should I use?
PRCIVIC
Take your pick.
Post by PRCIVIC »
Well guys either ECU will work with your setup after being chiped with Hondata but for the B18 I would choose the P75 0r P72 ECU because the P28 does not provide support for the Knock sensor. :wink:
If you don't drive a HONDA you ain't driving!
pissedoffsol
the LS has No knock sensor. no need for it on the ecu.
Brian@hondaswap.com
turbocivicex
Post by turbocivicex »
The P28 seems to have the least amount of problems. Knock is disabled with Hondata anyway, you will not need it with a good tune!!
pissedoffsol
least amount of problems you say...
I don't mean to sound like a dick-- but is there proof to back this up? I'm really just trying to decide which ecu I am going to send out to get 'chipped', and unless I hear otherwise, I am going to put the hondata on the p75 for my LS swap, as- well- its the ecu for the motor.
Any other thoughts?
-Brian
Brian@hondaswap.com
ECU for LS
It does not make any difference which ECU you use. Both the P28 and P74 can be made to run non-VTEC.
pissedoffsol
P74? I have a P75 :) I know, they are pretty much the same...
so, either or huh?
If it was YOUR car, which would you chip?
Brian@hondaswap.com
turbocivicex
It just seems from my experience and from reading these forums and the old ones. Things just work better with a P28.
pissedoffsol
but why?
Brian@hondaswap.com
Non VTEC ECUs
The P28, P74 and P75 will all work equally as well with V3. With V2.5 your choices would have been limited to just the P75.
inspecta83
Post by inspecta83 »
i converted my crx over to obd 1 and hooked up a stage 2b to my p75 but its not reving over 4k. i was wondering if this is b/c i should use the s200 instead or maybe im just missing something else? i was told that the 2b works with the p75. any input would be appreciated. thanks
