Daughter board communication error
PatCtr
Post by PatCtr »
Hi i read the other post from hondata, and i don't have a relocated battery. the battery is charging at 14.7 volts it is also fully charged.
symptoms: my radio keeps shutting off and turning on, the car wouldnt rev past 4k i disconnected the ecu, and started working again.
today i was driving, and the car shutoff for 4 seconds, and turned right back on. i checked the daughter board and made sure it was bolted down tight.
i also get connectivity issues when i plug my laptop into the ecu. I can turn the key on engine off 30 times, disconnect the ecu, change the plug, and resart the computer then it will work.
any ideas?
Re: Daughter board communication error
Are you the same person that posted that the hood prop was arcing on the battery?
